Hi Simon!
It would be nice to make support for switching I Q Branch in rtl-sdr in console server / client
thanks
73!
RTL-SDR Switch Q branch in server v3
Re: RTL-SDR Switch Q branch in server v3
That reads to be like using a top end Corvette to spend it's life driving a mile and a half to the grocery store and back. Besides, I think that capability is already there configuration pages. But, I've not looked lately and don't intend to.
Uh? What's wunnuv dem, mate? Loik a boiby Hast'n Mar'in?
Paul White (Grumpy Old Git)
Yes I can confirm there is no way to change to direct sampling mode, be it either I or Q branch when connecting to a remote server.
It would be a good idea to have a way of doing this.
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
IO92sc
G-QRP club 6129
Do you need to change this often or is it a one-off?ew8bak wrote: Tue Nov 03, 2020 5:57 pm Hi Simon!
thanks
73!
If he could make two definitions for the same dongle he could use that trick to change the sampling mode setting with one off settings in each definition.
I'm sure I can add this to the menus, just doing a few other non-radio things atm.jdow wrote: Sat Nov 07, 2020 8:52 am If he could make two definitions for the same dongle he could use that trick to change the sampling mode setting with one off settings in each definition.
Me too, cheers!Simon G4ELI wrote: Sat Nov 07, 2020 1:30 pmI'm sure I can add this to the menus, just doing a few other non-radio things atm.jdow wrote: Sat Nov 07, 2020 8:52 am If he could make two definitions for the same dongle he could use that trick to change the sampling mode setting with one off settings in each definition.
It's in the latest test team kit.PD3LK wrote: Sun Nov 15, 2020 10:15 pmMe too, cheers!Simon G4ELI wrote: Sat Nov 07, 2020 1:30 pmI'm sure I can add this to the menus, just doing a few other non-radio things atm.jdow wrote: Sat Nov 07, 2020 8:52 am If he could make two definitions for the same dongle he could use that trick to change the sampling mode setting with one off settings in each definition.
