pls make it possible, to disable SAM, or keep the selected mode "AM".
If I switch to AM, on the next tune to a station (i.e. point&click or mouse-scroll), SDR Console switches back to SAM.
Using 3.0.24, Airspy HF+ discovery.
Thanks!
Information also here: https://sdr-radio.groups.io/g/main/topi ... 0,76274756
73s Ernst
OE3IDE
AM / SAM
Re: AM / SAM
It shouldn't switch back to SAM if you simply tune. I can understand this if you select a Favourite or saved memory, but not simply tuning. Do you have an external radio connected?oe3ide wrote: Wed Aug 19, 2020 11:59 am Hi,
Thanks!
73s Ernst
OE3IDE
Re: AM / SAM
I understand you are using an external radio, do you have mode mapping enabled?oe3ide wrote: Wed Aug 19, 2020 11:59 am Hi,
Thanks!
73s Ernst
OE3IDE
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
IO92sc
G-QRP club 6129
Re: AM / SAM
yes, running the Airspy HF+ discovery, controlled via OmniRig from FT-2000.
Checked the mode-mapping setting. Is on "AM".
How it behaves, see here:
https://www.oe3ide.com/wordp/wp-content ... AM_SAM.mp4
73 de Ernst
73 de Ernst
Re: AM / SAM
Yes I can confirm, point and click and the mode changes from AM to SAM.
The same also applies if you are using ECSS-L or ECSS-U it also switches to SAM.
Mode mapping is set to AM for external radios.
This is only with an external radio tracking the main rain radio.
I never noticed this before myself.
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
IO92sc
G-QRP club 6129
Re: AM / SAM
What happens if the External Radio is not enabled? Please try this, will help me.oe3ide wrote: Wed Aug 19, 2020 6:47 pm Hi,
73 de Ernst
Re: AM / SAM
Simon, at my end it only happens with external radio enabled.Simon G4ELI wrote: Wed Aug 19, 2020 8:22 pmWhat happens if the External Radio is not enabled? Please try this, will help me.oe3ide wrote: Wed Aug 19, 2020 6:47 pm Hi,
73 de Ernst
The moment you switch the external radio on it pulls it to SAM.
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
IO92sc
G-QRP club 6129
Re: AM / SAM
Same here, if I stop tracking the external radio, it keeps AM.
73 Ernst
73 Ernst
Re: AM / SAM
OK, thanks - I know where to look.oe3ide wrote: Wed Aug 19, 2020 8:41 pm Same here, if I stop tracking the external radio, it keeps AM.
73 Ernst
