Frequency Database
Robert11
Frequency Database
Unread post by Robert11 »
What is the simplest and most straightforward method
of seeing which, of the several, databases In "Frequency Database Options"), is
open and being displayed for using ?
B.
Re: Frequency Database
Hi Robert, there's only one database FrequencyDatabase_001.sqlite in
C:\Users\yourname\AppData\Roaming\SDR-RADIO.com (V3)\Console\Ident0
This is a combined database of all individual 7 that can be seen on the pict.
You can however make/load differtent db's when you save them under different names.
For this use Archive XML save but take care because loading it overwrites your original database (FrequencyDatabase_001.sqlite) as far as i know.
btw you can select one of the 7 by filtering on "Source" collumn in your Frequentie Database list.
73, Leon
Robert11
From OP: Re: Frequency Database
Thanks for help with this.
Appreciated.
Bob
