Virtual audio line stuttering and oddities with sdr console
oh2eko
Unread post by oh2eko »
So recently guessing due to a windows 10 update Virtual audio lines became useless with sdr-console not sure what is causing it.
2 example videos
https://puu.sh/GQnbf/696ec34a80.mp4 Audio from sdr-console
https://puu.sh/GQnbF/fbfdbf55a1.mp4 Audio from sdr#
quick specs
Been trying different buffer settings to no avail and priority's
Re: Virtual audio line stuttering and oddities with sdr console
I'm really not interested in videos from SDR# as I use the WASAPI drivers, showing me videos from other software just gets in the way.
  • Which VAC software are you using?
  • Have you looked for an update to the VAC software?
  • How is the normal playback?
  • Console is using ~2% CPU but the task manager shows 42%, what else are you using?
You really are running a very fast display rate, makes videos hard to watch. Try 20 or 40 lines/second.
oh2eko
i have tried both VB cable and Virtual Audio Cable (VAC) latest with VB cable it does take a while before problems occur thou
Normal playback is fine if i put to default
is my main pc so plenty of things running.
Hi, did you tried the VB-Audio Hi-Fi Cable?
Download button is halfway this page https://vb-audio.com/Cable/index.htm
oh2eko
Hmm i do get some stuttering with the hi fi one to but seems to auto correct it self so at least by ear seems fine gonna see how a NOAA sat pass decodes.
khut
Unread post by khut »
After the latest Win10 updates, the stuttering occurred. I use both: VBAudio-cable and also Vitual audio cable. The following remedied:
1. Complete deinstallation of the VAC software, PC restart
2. Download the latest software versions:
https://www.download3k.com/Install-Virt ... Cable.html
- vac464full.zip
Filename: vac464.exe
License: Shareware
Date updated: 7/18/2020
https://virtual-audio-cable.de.uptodown.com/windows
- VBCABLE_A_Driver_Pack43.zip
- VBCABLE_B_Driver_Pack43.zip
3. Reinstallation and then perform sound settings.
oh2eko
Hmm would not help in my case as i had not had VB cable before and downloaded latest and HIFI one worked a bit longer then normal but same issue occured soon.
Suspecting windows did another Fudge up similar to the DPC (Deferred Procedure Call) in update 1903(i think)
oh2eko wrote: Tue Nov 24, 2020 12:45 am Hmm would not help in my case as i had not had VB cable before and downloaded latest and HIFI one worked a bit longer then normal but same issue occured soon.
Don't blame Windows, blame the VAC.
oh2eko
so turns out old driver files were still present after uninstall and update removing them manually has fixed the problem i think at least seems to be working correctly for now.
but Thank you for suggestions
and thank you Simon for the great software :)
