PTT via Pluto GPO pins
Also known as ADALM-PLUTO.
M0TGC
Unread post by M0TGC »
Hi
With the latest AD firmware (0.32) SDRC does not control the GPO pins on TX but with the F5OEO DATV firmware it is ok.
So, two questions:
Is there any reason not to use the F5OEO firmware?
Will SDRC drive the GPO pins on TX in the future on the standard AD firmware, or have I missed a way to configure it?
Thanks
David M0TGC
Re: PTT via Pluto GPO pins
M0TGC wrote: Tue Nov 24, 2020 9:44 am Hi
So, two questions:
Thanks
Thanks for this update - I wasn't aware that a new firmware had broken things. Noted, I'll update the code as soon as I have time.
Please give me a link to the firmware.
M0TGC
David M0TGC
So,
Maybe the new firmware has broken the library?
Has anyone else reported this?
I see this firmware is ~5 months old?
M0TGC
Are you sure it worked on 0.31?
David M0TGC
M0TGC wrote: Thu Nov 26, 2020 8:49 pm Are you sure it worked on 0.31?
I was told it did - I think. Please put FW 0.31 on and have a look, I have no way to test this.
M0TGC
Hi Simon
I downloaded the 0.31 firmware from:
https://github.com/analogdevicesinc/plu ... /tag/v0.31
Installed it and checked the version using putty. No PTT via GPIO on TX.
I then re-installed the DATV firmware from F5OEO and confirmed that PTT on TX was still working.
I have a relay daughter board in the Pluto simply switching an led as I am still waiting for the necessary PA's.
So PTT on TX is not working on either 0.31 or 0.32 AD firmwares!
Rgds
David
David M0TGC
Please attach your GPIO configuration window.
M0TGC
Simon G4ELI wrote: Fri Nov 27, 2020 5:29 pm Please attach your GPIO configuration window.
Where do I find this?
David M0TGC
Options in the radio panel, just above RIT and XIT.
