a. Any tentative future plans to add more digital decoding modes in the program to negate
any need to port over to some third party decoding program ?
e.g. HF Acars, regular Acars, Navtex
b. Scanner capability still on 2021 list ?
Incredible program.
Bob
Additional Digital Modes ? Scanner ?
Re: Additional Digital Modes ? Scanner ?
Digital - i would like to write a full-blown digital mode program, a scanner is my first major project for 2021.
Aloha Simon
I would be interested in the scanner features. would it be possible to include NOAA SAME code Alert, message decode and record audio?
I believe this is correct
"SAME is transmitted using AFSK, at 520.83 bits per second, with a mark tone of 1562.5 Hz and space tone of 2083.3 Hz. Individual bits last 1.92 ms. Each byte is eight bits with no error correction, and the most significant bit is always 0 and transmitted last. Each message is repeated three times in lieu of error correction, with the receiver intended to "vote" (best two out of three) to determine correct bit value."
https://www.weather.gov/nwr&ln_desc=NOAA+Weather+Radio/
https://github.com/cuppa-joe/dsame
Gary
WH6EPS
Gary
WH6EPS
