Scaling?
N2EIK
Scaling?
Unread post by N2EIK »
Are the stand-alone tx/rx windows "scalable"? In other words, can they be scaled down to show the entire panel without cutting off the bottoms as shown?
N2EIK
Re: Scaling?
pauldbnut
Re: Scaling?
Unread post by pauldbnut »
"can they be scaled down to show the entire panel"
If you had every panel expanded, a complete window would have really tiny panels.
Is that what you are asking for?
Paul White (Grumpy Old Git)
N2EIK
Re: Scaling?
Sort of, I guess. if you look at the photo I attached, the TX/RX panels are cut off at the bottom. I cant make them the full height of the monitor. They have a slide bar on the side. I would like to see the panels full and realize the graphics will be somewhat smaller.
btw, I use three monitors. floating tx/rx on the side, this allows console to be larger, console on the center and any digital (or chrome, etc) on the right side monitor.
My res is set for 1920x1080
Re: Scaling?
just drag the panes to one of the 4 arrows in the center and release it there.
see picture
N2EIK
Re: Scaling?
Thst only seems to dock or undock. When the panel is floating , it does not display the full contents of the panel, there are slide bars on the sides. I do not want to dock, I want floating.
Re: Scaling?
Hi, it can be done on a 4K screen but i think it will never be readable with 1920x1080 HD resolution, even if Simon would make everything shrinkable. grtz, Leon
