Hello Group,
I am using World Clock v1.0.15 and I am having an unusual problem. I have Greyline with Shadow enabled. When I first enable it, the display looks perfect. However, as time goes by, the edge lines move as expected but the shadow remains fixed. I have attached the screen shot. I can run the identical version of World Map on two other PCs and they both work perfectly.
I am running an HP Pavilion dm3 notebook PC:
AMD Athlon II Neo K325 Dual-core Processor 1.30 GHz
4 GB RAM
Window 10/64 Home, Version 20H2, Build 19042.630
This laptop is dedicated 100% to Simon's World Map and the only other "user" software running is Dimension 4. It's a slow, old laptop but it seems to run the Map almost fine.
Thank you for any suggestions that you can provide!
73,
Jim W7EED
World Map Greyline Shadow "Fixed"
Re: World Map Greyline Shadow "Fixed"
Thanks for the screenshot - you're not the first person to report this but so far I failed to resolve it. Will look at this problem...
And reproduced it, new fixed kit tomorrow.Simon G4ELI wrote: Mon Dec 21, 2020 8:03 pm Hi,
