Elad S3 & Data Analyser
Moderator: NN4F
Re: Elad S3 & Data Analyser
Thanks Simon, will do
With help from a friend it appears to be overload that's causing the problem. I have tried some recordings beaming away from my local Newhaven TX, and with my masthead amp off and so far they have been OK. Will keep trying and see if that was definitely the problem.
Thanks for your help Simon
Mike
Mike
Ah,
Glad you found it. You really shouldn't need a masthead amp on Band II unless you have a very long run of grotty coax.
Glad you have it sorted Mike. Never really got a chance to fully look at this up til now (back at work).
