When I am chasing NDBs, I do it visually with the waterfall. I use the X8 resolution which is pretty good for closely packed beacons. But there are times when it isn't good enough. I have tried slowing down to 10 lines/sec which makes a smaller bin width but then the cw ident becomes too squashed to be legible. I was wondering if a resolution option of x16 might be a better way.
Thaks,
Tony
Higher resolution
Re: Higher resolution
A resolution option x16 would also be desirable observing very weak signals of spacecraft in the DSN band.
Possible to have this option?
Thanks, Rocco IK8XLD
In theory - yes. Am between projects, will take a quick look at this.ik8xld wrote: Mon Sep 13, 2021 10:05 pm A resolution option x16 would also be desirable observing very weak signals of spacecraft in the DSN band.
