Elad S3 > Images in Wideband Mode
Moderator: NN4F
Fenu
Unread post by Fenu »
If the S3 is set with Bandwidth 24.576MHz and the Range Slider below is completly on the left side, the V3 produce images in the upper frequency range from the medium wave.
Regards
Fernando
Re: Elad S3 > Images in Wideband Mode
I'm not a technical expert with the finer workings of SDR, but what you see there is normal. Google "SDR aliasing" or similar.
Fenu
G0OFE wrote: Fri Jan 22, 2021 5:01 pm I'm not a technical expert with the finer workings of SDR, but what you see there is normal. Google "SDR aliasing" or similar.
You could be right. SW2 does that too ...
Thanks for the hint.
