Is there an operating manual for 3.0.26 or .27? Yes or No?
If not current, what is most recent, please???
Thank you
Jerry AB5R
Current Manual
Re: Current Manual
Negative
Always download from here, 3rd party downloading is always questionable or not up to date:
Scroll down about halfway down the page, when you see the download for Simon’s World Map, STOP!
3.0.26 is the current public release for now.
You can always post questions to the group if you have issues or questions on operating SDRC.
Re: Current Manual
Jerry
Closest thing to a manual is all the information on Simon's website:
https://www.sdr-radio.com/
Hover over all the header menu items at top of page and there is a lot more information in there than it first appears, including from the many hover-dropdown submenus.
If you need help to get going from scratch, then Kriss who posted an earlier reply to you has written an excellent annotated guide to set-up with radios and SDRC server-based radios (of which there are many, including many that Kriss runs). Just at the minute not sure where Kriss's guide is. Think is posted on the old IO Group, but no doubt he will give you a link if you ask for it.
Other than that, asking here will hopefully always get a helpful response.
AB5R wrote: Sun Jan 31, 2021 8:09 pm Is there an operating manual for 3.0.26 or .27? Yes or No?
Thank you
Jerry AB5R
Re: Current Manual
Found Kriss's excellent start-up guide. Even if you are past that stage Jerry, others may find it useful if arriving here from searching/finding the "manual" heading of this post!
https://sdr-radio.groups.io/g/main/message/53082
If using your own SDR hardware, then where Kriss shows selecting V3Server, select your local radio instead from the Radio list.
Good luck
Good luck
Re: Current Manual
The above link Max posted is how to set up a Server, you want this one on how to set up SDRC to use servers or your own SDR locally:
https://sdr-radio.groups.io/g/main/message/51635
Re: Current Manual
Thanks Max & Kriss:
I have 3.0.26 installed and working fine. I suspected that a ".26" manual was not out yet but hoped that previous manual might hit the high points.
I not having problems (currently anyway) just needing guidance on the many facets of the OUTSTANDING program.
I did try to update the satellite keps from "nasabare" but did not update. SATPp32 from AMSAT has recent keps and includes RadFx Sat-2 listed. I don't know IF you can manually add two line keps for a satellite in SDR-Console. THUS, my search for a manual.
Thanks guys!!!
73,
Jerry
Thanks guys!!!
73,
Jerry
