Elad fdm duo trx
Mag loop Simon
Elad fdm duo trx
Unread post by Mag loop Simon »
Hello
A..Would it be possible to “ speed up” the tx frequency window??
What I mean by this is rx window is often down at rx antenna bit, so one can not see rx frequency..so relying upon tx window ( have rx=tx.)
However when tuning the delay on updating tx frequency is very long..would be nice if was updated much more often..
B.. swr on sdrc..lags behind actual swr by a good second or so..
Now for checking swr not an issue..but i use mag loops..so when tuning, which is critical on 160m ( circa 2khz bandwidth) i get a major overshoot..
Ie tune..but swr on sdrc is 1 sec behind actual swr..= bugger to tune loop..when running 400w kinda important to get tuning spot on..
Other than that sdrc on elad is SOOOOO much better than sw2!
Oh..
C..is there a hardware setup on sdrc so i can change filter outputs on com port on duo?? ( to run auto frequency change on my homebrew amp?
Thank you Simon
Re: Elad fdm duo trx
Screenhots would help here please. I get the impression that your PC is a bit overloaded based on this lag, so lets see the console and also Task Manager.
