VST 2.x Rea EQ (Rea Plugs Edition) external addon plugins.
Suggested by VU3OBR, Saro.
Some great plugins here.
VST plugins
Re: VST plugins
also reaGate. I followed a tutorial on reducing noise in obs recordings designed for microphones so it only picks up your voice and not background noise between you speaking.
Turns out reagate is the most powerful, performant, capable, and smart squelch that exists in software.
- rms dunno if other squelch solutions have a tunable rms, but this basically allows dynamically choosing to average noise levels over a window of time. helps not trigger the gate with transients.
pre open delays audio a bit but allows opening the gate before the gate triggers, so the start of words or signals don't get clipped
tunable lowpass/highpass and attack/hold/release are useful
wet/dry mix - this is so useful. like, i can set the wet mix to 40db lower and it feels a lot less jarring than just on/off squelching.
Re: VST plugins
Hi Simon, new to SDR but love Console. Got my head around it now, great kit.
Is there any way to route the audio internally so I can use my vst plug ins? Be great to just patch them in the chain.
I run Cubase 11 Pro. Be fab to use them in Console. Like this one.. This would be perfect
https://www.izotope.com/en/products/insight.html
