Is it possible to have the scale settings ( the Low and High sliders that pop up when you hover over the top right of the spectrum pane) changes according to the band in use?
I have the RSP1A tuned to the 9MHz IF of my transceiver, with the frequency display showing the frequency the transceiver is tuned to.
I find I need to mess with the Low scale as I change bands on the transceiver. It would be nice if these settings could be saved and automatically recalled based on the frequency of the transceiver.
I would not be at all surprised to find that it is possible, but I simply haven't figured it out yet.
John
G4DRS
Scale - High/Low - per band?
Barry WB2ZXJ
Re: Scale - High/Low - per band?
Hi John,
If you have created a Favorite for each band, you can save the range and levels for each by checking the appropriate box (see attached).
Barry
WB2ZXJ
Barry
WB2ZXJ
Thanks, Barry.
I was hoping it would be automatic.
The SDR is just a display for me, I don't interact with it any more than I have to.
John
G4DRS
John
G4DRS
Hi, you can set the High Setting on automatic: tab View, Scale button: High: Auto
Unfortunately Low can not be set to Auto.
