Hi @ all,
i installed the Server Manager and there is a limitation to 1 mhz. Is there a possibility to change it to 2 mhz in a config file oder something like this?
Manuel
Server bandwith
Re: Server bandwith
Hello, I am also having this issue. I have a server setup thru a lan network. i use a HackRF. When i connect locally i can get 20mhz of bandwidth, but when i connect to the server i can only get 250khz of bandwidth. How do I get more?
If i use my rtl2832 on the server I can get 2.4mhz of bandwidth.
Re: Server bandwith
See attachment.
Re: Server bandwith
I have worked with the bandwidth settings and I can only make the bandwidth smaller. I have ticked compression on and off. 250khz is as high as I can get it.
I did notice that I had to restart after each change. Any idea what Im doing wrong???
As i said before, my rtl2832 will allow 2.4mhz bandwidth.
Could this be a definition issue??
malimaster
Re: Server bandwith
Same by my configuration: 1 mHz is the max setting.
magesticmage
Re: Server bandwith
I too have this problem, cant get over 1Mhz even though i set it higher in the server
i noticed this after installing the latest version SDR-Radio V3.0.28, 64-bit, 2021-06-30_1859
see attchedments
what is "Low IF" mean?
see attchedments
