Is it possible to Average/Integrate Spectrum buckets with Console? Air Spy has Astro Spy and other applications support averaging for a given sample count. Thanks and enjoy, John.
EDIT: I am running 3.0.27 Preliminary on an Air Spy. I tried Smoothing in View. When I click on Spectrum, nothing happens. I find little information on how to use it and obviously do not know. Help would be appreciated!
Average/Integrate Spectrum buckets?
Re: Average/Integrate Spectrum buckets?
NO6B, I have tried this with little luck. I am busy with another problem, but will try it later. Thanks, John.
Hi,MisterJ wrote: Sat Apr 10, 2021 12:04 am NO6B, I have tried this with little luck. I am busy with another problem, but will try it later. Thanks, John.
There are things happening in the background so that the data is already averaged / interpolated to one value per DIP (pixel). Smoothing introduces algorithms to reduce the visual noise and make signals easier to see.
If you do have problems just post a screenshot.
The defaults should be good.
Thanks much, Simon. I will work on this in a couple of weeks. I was looking for the effect I see with AirSpy's AstroSpy. Thanks, John.
John,MisterJ wrote: Sat Apr 10, 2021 12:37 pm Thanks much, Simon. I will work on this in a couple of weeks. I was looking for the effect I see with AirSpy's AstroSpy. Thanks, John.
Not being a user of AstroSpy I have no idea what it looks like, so next time maybe a screenshot or video?
Thanks, Simon. I will. Enjoy, John.
Here are the screenshots I promised. The first is right after starting integration in AstroSpy and the second is after some time integrating. Please ask any questions. Thanks and enjoy, John.
image post
image post- Simon G4ELI
Why not past screenshots as attachments to your message rather than hosting externally?
Having viewed the images this request is beyond the scope of a real-time spectrum display. I do see how it could be of use but I can only support this via an additional feature.MisterJ wrote: Tue Apr 27, 2021 9:28 pm Here are the screenshots I promised. The first is right after starting integration in AstroSpy and the second is after some time integrating. Please ask any questions. Thanks and enjoy, John.
