SDRplay TCP server support
m3ghe
Unread post by m3ghe »
Any chance of incorporating SDRplay TCP server support? In particular the extended support.
USB connection using API V2 an V3 is already supported. But we seem to frequently get posts about connecting using TCP.
You can connect using RTL_TCP compatibility but it is seriously crippled, using SDRplay's extended TCP server would be much better.
Information on this from SDRplay can be found here https://www.sdrplay.com/docs/SDRplay_RS ... _Guide.pdf
I'm sure this subject has been broached before, but can't see how it ended.
Martin
m3ghe
IO92sc
G-QRP club 6129
cjbazen
Re: SDRplay TCP server support
Unread post by cjbazen »
+1 on this feature.
As there's already server support for the SDRplay radios I'll not be adding this, sorry.
