Second HackRF
JamesBrown
Second HackRF
Unread post by JamesBrown »
Can I open a second instance of SDR Console and use that to open a second HACKRF?
I can see both Hacks in the Device Manager but how do I select them individually?
Re: Second HackRF
If the HACKRFs have no serial number fetch in their software API the only way is "luck of the draw". If you do not like what you get the first time leave that running and open a new SDRC. Select the remaining one there. With luck that should work.
Re: Second HackRF
Looking at the code, you can't select which hackRF you open.
The API has been updated, I have to add the support you need.
https://github.com/mossmann/hackrf/wiki/libHackRF-API
