I've gone through the setup procedure for the server but I found that when searching for my radio on SDRSpace.com, it is listed but there is a yellow warning triangle next to it and not the green tick. I also discovered there is a red icon listed in the Server Manager setup under "On Air".
I assume this is most likely a port forwarding problem. I used a several online services to check my port 50101 but it's still showing as closed. I have a NetComm NF18ACV wireless modem, and another wireless router attached to this for improved coverage around the house. Rather than tackle port forwarding in both units, I've initially set up the port forwarding on the wireless modem only and initially just using this to connect my "remote" radio and my armchair laptop to. I assume the attached additional wireless router wouldn't cause any issues here.
Attached is a screenshot from my wireless modem port forward window with my local address in. I've also tried my online IP address in there but I'm not getting very far and would like to ask for some help with this please.
Thanks.
Dave
