I would like to have QO-100 beacon sync without secondary windows and clicks.
My desired solution:
- I tune (USB usually) until I hear the beacon
- I press a keyboard shortcut (whatever that may be)
- The program syncs RX with the beacon
- The program re-tunes to the beacon frequency, so I don't get "lost" in the band
Thank you
Hugo
CT7AOV
QO-100 Beacon Sync without secondary window
dg9bfc_sigi
Re: QO-100 Beacon Sync without secondary window
autolock if psk beacon is found inside a 2-3 kc window would be nice ... so one could use the beacon without the need to catch beacon with the mouse and press "play" in beacon window ...
