SDR-IQ Not Playing
Re: SDR-IQ Not Playing
#11
KA1GJU wrote: Tue Aug 17, 2021 6:17 pm The issue is on a w7 64bit machine, not W10. Worked as it should when plugged into a W10 machine (Super Station #1 Server).
Kriss
OK, could be the driver version, back of my mind I think this is the problem. I used to have this written down but...
#12
(Waving arms wildly) Danger Danger Simon Robinson Danger You are getting old! Don't do that!
(And what did you do with Dr. Zachary Smith?)
(And I have had a chance to fondle the actual object that uttered a phrase a little like the above. WHEEE!)
{O,o}
W4RLS
#13
Unread post by W4RLS »
Attached is my log. It looks quite similar to that of KA1GJU where it says device not found. My machine is Windows 10 Pro, 64-bit.
-- Bob, W4RLS
SDR Console tmp.txt
(2.5 KiB) Downloaded 292 times
#14
W4RLS wrote: Mon Aug 23, 2021 9:25 pm Attached is my log. It looks quite similar to that of KA1GJU where it says device not found. My machine is Windows 10 Pro, 64-bit.
-- Bob, W4RLS
This log shows the driver failing to find the device, apart from suggesting a different driver version I have no suggestions.
W4RLS
#15
With the release of Build 2365, my SDR-IQ is now recognized and again works with SDR Console. The serial number now appears and the SDR-IQ functions.
Thanks.
Bob, W4RLS
#16
Good news.
My first SDR was the SDR-IQ.
