Cannot Go on Air
ik8ozv
Cannot Go on Air
Unread post by ik8ozv »
Hello All,
i hope in an help.
I am using SDR Console v. 3.1 Build 2320,
I have made some settings in it and now whe i try to go on TX it seems it won't to go.
I have tried with bot Tune and Tone but i do not see my signal on the waterfall.
Yes the Beacon is locked with the Geostationary Satellite Beacon option.
It is like the TX has been inhibit but i cannot find which parameter does that.
Please any help will be really appreciated.
73's de Enzo IK8OZV
Re: Cannot Go on Air
Hi Enzo
Please show a full screenshot with the radio in the problem condition (i.e. in Tune but no output). See here:
Do not crop or edit the screenshot. Please post as an attachment (select "Full Editor and Preview below the forum message window to post attachment).
What is your hardware?
You say you do not see your own signal on the waterfall. Which waterfall? Have you confirmed no power out with power meter or second receiver? You can use another instance of SDRC with second SDR (dongle?) to use as monitor receiver.
ik8ozv
Hello Max,
here is the screenshot.
This is TXing with the TUNE:
and this TXing with the TONE:
Apologise but i did not understood how to attache it to the message.
My Hardware is a Pluto with a CN0417+EDUP AB007 PA+F4SVG big PA.
I mean that i do not see my own signal in this waterfall:
I am sure that it is something in the settings as if i use the same hardware on another PC
or if i uninstall and reinstall on the PC that i have the issue, i will not have the problem, bur
as i go to set the program as i had i get again the problem
74's Enzo IK8OZV
No images seen. To attach images, click "Full Editor & Preview" button below the message (in the forum web interface) and then the attachments facility will become available:
