What is the problem to add simultaneously decoding RDS on all frequencies from bandwidth? I guess hardware is already ready for this (in my case Elad FDM-S3 + Core i9-9900).
Thanks for the great software!
Decoding RDS on all FM frequencies simultaneously
Vladimir Doroshenko
Re: Decoding RDS on all FM frequencies simultaneously
The only way you can do this is open as many receivers as your machine will allow - up to 24. Each one will decode RDS.
You can set up banks of receivers in Favourites - that is what I have done. I can get away with 20, though the machine starts to creak a bit by then!
There is no current way to scan up and down the band automatically logging RDS as you go.
Vladimir Doroshenko
Jim, thank you for the answer. I know about multi-channel monitoring since 2016 from this article.
But this method is not very comfortable. Especially, during Es.
Probably no ideal method.. what SDR are you using for FMDX?
It's made easier for me now I have the Elad S3 - I just record the whole band!
On playback, if RDS is logged, the log entry marks the time of the recording, rather than the current time, which is a real plus. No mental gymnastics needed.
Vladimir Doroshenko
Ah... Not seen that before.
Vladimir Doroshenko
While developers are thinking about new tools, I have to do perversions like this:
