favorites not shown in horizonal format as in previous kits
JOHN
Unread post by JOHN »
The favorites folders are not shown in a horizonal bar going across in favorites as in previous kits, I have searched everywhere in console settings but found no way to restore it. They are now in an entry called bands, and will drop down to show all folders for the frequencies saved, but disappear when any are chosen, and you have to go through the routine of accessing the band entry to select another frequency. See snapshots attached for meaning.
Re: favorites not shown in horizonal format as in previous kits
View->Frequency Database does not bring it back?
The horizontal bar shouldn't stay visible. I suggest you break Bands up into - say - 5 sub-bands, e.g. Bands I, Bands II etc.
JOHN
jdow, the favorites do not show in the frequency database.
Simon, I will try your suggestion, was not trying to cause trouble by my question, just wanted to insure I hadn't changed anything myself by mistake. The favorites folders only stay visible until you make a choice of a frequency in one of the folders, and, if you want to change frequency choices again you have to select the favorites button to show saved frequencies and folders again. I was afraid I had screwed something up as it didn't act as it did in previous versions. Thank you both for answering quickly.
Try using the Tree Pane
