Listening to single file in chain
DonMooreDXer
Unread post by DonMooreDXer »
I have a chain of 24 files recorded from 0757 to 1105 UTC. I want to only listen to a specific file in the middle. Is there a way to only open a single file in the middle of a chain? (As opposed to selecting 0757 and having the entire three hours in playback.)
Re: Listening to single file in chain
You can use the Navigator function to jump to a specific minute in a recording, or specify a range of times between which to listen to a recording, or loop it.
DonMooreDXer
Thanks, but not the same thing. But I did figure out a work-around on my own. I simply copied the file to another folder by itself.
DonMooreDXer wrote: Thu Dec 02, 2021 2:11 am Thanks, but not the same thing. But I did figure out a work-around on my own. I simply copied the file to another folder by itself.
Consider the Data File Editor as well.
