SDRC v3.1 3AUG2021
WIN10
Greetings
Bug(s) :
1) 'Memories' entries set to BC-FM revert to Narrow FM after ~1 seconds after selection, a 2nd click sticks to BC-FM
2) filter width on display not reflecting BC-FM selection
3) BC-FM entry on Main Screen 'Mode' dialogue shows "175kHz Max BW", inconsistent with (faulty) single filter indicator line appearing at +112kHz when BC-FM is invoked via Memories entry
A) When using 'Memories' feature to store Broadcast FM stations :
- Mode : BC-FM
- Filter : None
B) Select (click) a Memory button for a (configured) BC-FM station
C) SDRC selects the channel initially set to BC-FM, station plays normally for about 1 sec
D) after ~1 sec Mode switches to NFM (with NFM modulation)
E) a second click on the same Memories channel then causes Mode to switch to BC-FM, which stays and plays/sounds normally
F) Exception : a single 'filter indicator line' appears at +112.5 kHz above set frequency when Mode is selected to BC-FM
- if 'Filter' is set to 225000, "Filter' stores as "-112500 to +112500", only single line at +112.5 kHz above set frequency still appears
G) Exception : Main Screen Filter 'Select Mode' BC-FM dialogue entry reflects '175kHz Max BW', which is not consistent with the filter line displayed (at +112kHz)
H) when Main Screen 'Filter' is selected to 225kHz then the Pan display correctly displays the 225kHz filter
Thanks for all Support,
Paul
N8CVW
Memories for FM Broadcast switch to Narrow FM
UPDATE Re: Memories for FM Broadcast switch to Narrow FM
Greetings
it so happens that BC-FM falls over into NFM when just changing frequencies by clicking signals on the spectrum display
Paul
N8CVW
Paul
N8CVW
What SDR hardware are you using Paul?
Is it only a External Radio? in that case have a look at Program Options - Controllers - CAT - Mode Mapping
If that doesn't help then tell us what happens when you make a Favourite iso a Memory entry.
Or pls send us a full printscreen of SDR-Console incl the mode mapping pane. (use the camera icon provided in SDRC)
73, Leon
73, Leon
