I would like to ask, if there is a possibility to send only spectrum data and audio from the server to the client.
With larger RF bandwidth (e.g. 8 MHz from a SDR-Play device), the bandwidth of the I/Q data becomes way too large for WAN connections.
At the server side is enough CPU power available to do all the FFT, but often the WAN bandwidth is limited.
As a workaround I'm using RDP with remote audio. But unfortunately remote audio is messing up other audio interfaces
Best regards: Christoph / HB9DTZ
