New QRM to all KA1GJU Super Stations at my QTH
Any users of my system notice when this QRM started?
VERY broad banded, and effects all HF bands. Noticeable on ALL SDR's here at the QTH! :x
I have a hunch it may be a powerline insulator arcing due to the sound and width of QRM.
See the examples attached:
Note the spacing between gaps appears to be same (like a timed pulse), but it appear to be random. Will be silent for extended periods of time, then randomly appear and disappear.
Time to bust out the active loop and do some DF'ing!
17M Screen Shot
17M Screen Shot
75M Screen Shot
75M Screen Shot
Re: New QRM to all KA1GJU Super Stations at my QTH
Update:
Located the offending pole and reported it to local power company.
Drove around with AirspyHF+ and a massive 17M hamstick and observed the sharp increase, and then decrease in signal in the area.
Walking over with an FT-817 and a 1.5 foot whip, it's S-7 at the pole. Noise goes nuts when I shake the pole via the ground wire. Loose
connection on the transformer feeding two homes or the fuse feeding one home.
Just tryin to keep the noise floor low for all the users!
If it appears to be a bad ground connection or even a bad power connection to a house you have a safety issue to push here rather than the EMI "side issue". That might get action a tad quicker.
