Visual Playback Window
m0mst
Unread post by m0mst »
Hi all,
Hope someone can help me try and work out what I have not done.
I use SDRConsole for FMDX. I have a Remote Station and my new portable station. When playing back IQ files from an opening on my remote station, my playback window is a visual playback, which is fantastic for catching the stations during an E's or MS opening.
I have attached 2 images, 1 showing how my remote system looks,
and 2nd how my portable looks. Both are using Nvidia Cards and CUDA is enabled on both.
I am sure its a simple setting, but find it I cannot.
Any help greatly received.
Dan
M0MST
Re: Visual Playback Window
Hi Dan,
You need to enable the Navigator window and drag and snap it in place. In the first picture you have, in the 2nd, you havn't.
m0mst
Hi Jim,
I have moved it and snapped it to the bottom, unless something else I am missing?
In the 2nd window and your 2nd post, you're using an older version of 3.1........
m0mst
Sorry Jim my bad,
Updated and sadly still doing the same.
Barry WB2ZXJ
Unread post by Barry WB2ZXJ »
In the Playback window, select Layout/Bitmap.
Barry
WB2ZXJ
m0mst
Thank you both, All now working.
Dan
M0MST
