SDR PlayRSP2PRO after 1.42 0720 update
SDRPLAY has updated the SDRUNO software to version "1.42-0720" and the API to version 3.10. When I start SDRConsole it doesn't recognize the RSP2Pro (other SDR software without problems). Please find a screenshot and logfile attatched:
- W1EGB logfile July 22 2022.txt
- (20.48 KiB) Downloaded 256 times
Re: SDR PlayRSP2PRO after 1.42 0720 update
The API release note probably says it all.
API/HW Driver 3.10 beta 6 RSP Control Library + Driver 15-Jun-2022 Release Notes
Supports all RSPs & x86, x64 and ARM64 OS. Windows 7 and up. Required for 3rd party applications & developers. Installer may require device reboot. After installing v3.10, please do NOT attempt to install an earlier version of the API. This will result in problems
This program is a beta release, and so may not perform as expected. Download only if you accept that there may be issues.
