Hello - I'm trying to understand how to set up SDR-Console's satellite tool to automatically record satellite I/Q data based on the schedule. I can't quite figure out how to set up and enable automatic recording. I opened the Automatic Scheduler window, clicked on the Schedule button, choose several satellites, click OK to close the window and then press the On/Off button to show 'On'. My expectation is that I would find wav files in the directory configured in the Recording Tab / Options button after the pass. However, this doesn't seem to work for me.
If I click on Home Tab / Enable Tracking, SDR-Console records the I/Q data for the selected satellite during the passes. (I think I also had Recording Tab / Data /Automatic enabled, but now I'm confused!
So -which buttons need to be pressed to enable automatic I/Q recording of the satellites listed in the Automatic Schedule window? I have found the following buttons that may or may not be associated with what I'm trying to do.
Home Tab / Enable Tracking - does this enable Automatic Schedule recording? Or, only recording of the satellite in the main tracking window?
Automatic Schedule Window - ON/OFF Button - I think this should enable automatic scheduling, but it doesn't work for me. Is there another button that should be enabled?
Recording Tab / Data /Automatic - What does this enable?
SDR Console Main Window / Rec/Playback / Data::Scheduler / Start - does this button have anything to do with the satellite recording?
The radio (SDRPlay) is started and running.
Thanks for your help. This automatic recording is a feature I can't find elsewhere.
73!
Automatic Recording Satellite - version 3.2
Re: Automatic Recording Satellite - version 3.2
I have exactly the same question. Have you found an answer yet?
poisenoire
Bump for this question.
Using both latest (Beta) and latest stable, I cannot get automatic recording to work with the scheduled passes. Automatic recording works fine "manually" when I enable tracking for a specific satellite. It never records from the satellite automatic scheduler.
I have verified minimum elevation. I/Q recording is on.
I have tired with automatic recording option enabled and disabled.
Is there some trick to getting it to record the passess via the satellite automatic scheduler? It's working fine otherwise and a fantastic program, just need this to function as it apparently is supposed to. From reviewing this board, it appears others have this working.
Hi, two years later the exact same problem here on the V3.4 3871
73,
Stefan
73,
Stefan
