Difference between RX-888 and RX-888 MK2
skyking_comms
Unread post by skyking_comms »
I own the original RX-888 and wondered what the differences are between that and the MK2? Basically is it worth the upgrade..
Thanks
Re: Difference between RX-888 and RX-888 MK2
Higher sample rate (double) and some added gain control as I remember. I have to get back on making a SourceRX888 dll to sneak in after making it look a little bit like an rtlsdr dongle to SDRC.
skyking_comms
jdow wrote: Wed May 11, 2022 11:21 am Higher sample rate (double) and some added gain control as I remember. I have to get back on making a SourceRX888 dll to sneak in after making it look a little bit like an rtlsdr dongle to SDRC.
Thank you
N6ATC
Unread post by N6ATC »
skyking_comms wrote: Mon May 09, 2022 6:07 pm I own the original RX-888 and wondered what the differences are between that and the MK2? Basically is it worth the upgrade..
Thanks
In this blog post, you can see Jinze (Justin) Peng's announcement of the MKII, and he outlines the differences.
https://swling.com/blog/2021/02/new-rx- ... n-the-way/
