Easy access to tuning steps.
m3ghe
Unread post by m3ghe »
Would it be possible to have easy or quick access to tuning steps?
They say a picture is worth a 1000 words so,
Martin
m3ghe
IO92sc
G-QRP club 6129
Re: Easy access to tuning steps.
Martin,
That's a great shout - only bit I'd add is the "..." button to edit your step buttons.
I don't know how quick/easy it would be to implement, but it would be handy to have at times.
I agree Martin and I (and others) have requested this before. My temporary workaround is I have keyboard shortcut set up to recall the "Options". I have it set up to be called by "Ctrl + O" (letter O).
If the last window within options was the "Step" window, then this is what comes up next time it is opened, so Ctrl+O becomes the "Steps" shortcut. Works OK for me to get by until the feature is (hopefully) added.
By the way, the menu that comes up when selecting "Options" is remembered even if SDRC is closed and opened again multiple times.
Also what might be nice is if the step size is one of the things (optionally) memorised with a saved Favourite?
Easy to add. I'm not in a mode for brain-draining coding so will add this now.
G6PZZ
Unread post by G6PZZ »
As a MW DXer, i would appreciate 9kHz and 10kHz being two of the choices. Switching between US and EU channel spacing would be a delight and hopefully well-received by our US cousins.
Thank you Simon
Tom G6PZZ
goscickiw
Unread post by goscickiw »
Also, it would be nice to have the tuning step automatically switch depending on the selected receiver's frequency.
goscickiw wrote: Sat Sep 19, 2020 5:21 pm Also, it would be nice to have the tuning step automatically switch depending on the selected receiver's frequency.
Not a chance!
m3ghe
G6PZZ wrote: Sat Sep 19, 2020 5:00 pm As a MW DXer, i would appreciate 9kHz and 10kHz being two of the choices. Switching between US and EU channel spacing would be a delight and hopefully well-received by our US cousins.
Thank you Simon
Tom G6PZZ
I agree.
In my mock up you may not have noticed but I was in NFM mode so the steps reflect that.
What I am hoping for is the steps change to reflect the mode, maybe? Or maybe not.
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
Simon G4ELI wrote: Sat Sep 19, 2020 5:37 pm
Not a chance!
Not sure I would want that.
Martin
m3ghe
IO92sc
G-QRP club 6129
