Why not? That doesn't seem like something hard to code. And if you don't want to use it, you could just not enable it.m3ghe wrote: Sat Sep 19, 2020 5:42 pmNot sure I would want that.Simon G4ELI wrote: Sat Sep 19, 2020 5:37 pmNot a chance!goscickiw wrote: Sat Sep 19, 2020 5:21 pm Also, it would be nice to have the tuning step automatically switch depending on the selected receiver's frequency.
Easy access to tuning steps.
Re: Easy access to tuning steps.
One objection is that providing frequency-dependent receiver configuration requires a new "layer" that might be called "band plans".
Apart from being a whole new tranche of coding and "database maintenance", this would also need to offer user-defined configuration.
Different parts of the RF spectrum have shared (overlapping) service allocations, often with different channel spacing (and modes).
Users will have individual preferences for service type, hence tuning step. And may want to choose between different services at different times.
If Simon pushed out a simplified "plan" for just Am/BC/whatever, there would be never-ending requests for extension.
Rather a big ask IMO.
As it is, we don't even have a ribbon showing (user-selectable) ITU frequency allocations - a big task in itself.
Paul White (Grumpy Old Git)
Other programs have these features and there doesn't seem to be a problem. Maybe the band plan part (which is another feature that I'd like to have) could be some kind of a module that someone could replace with their own if they needed something more advanced?
No auto step for me thanks. If it was a feature it should be possible to switch it off.
But, as mentioned earlier, it might be nice to save the step size with Favourites data, as is the case with the mode now. This would allow a Favourite for different band to be saved with step size and would actually achieve a "semi-auto" feature via a roundabout (but to me nicer) route. e.g. Save one favourite for AM band , 9 kHz steps and another favourite for AM band, 10 kHz steps.
Well please use the other programs which support this! I will be adding a band plan.goscickiw wrote: Sat Sep 19, 2020 6:21 pm Other programs have these features and there doesn't seem to be a problem. Maybe the band plan part (which is another feature that I'd like to have) could be some kind of a module that someone could replace with their own if they needed something more advanced?
I use SDR# too, however for most things that I do SDR Console is better.Simon G4ELI wrote: Sat Sep 19, 2020 7:00 pmWell please use the other programs which support this! I will be adding a band plan.goscickiw wrote: Sat Sep 19, 2020 6:21 pm Other programs have these features and there doesn't seem to be a problem. Maybe the band plan part (which is another feature that I'd like to have) could be some kind of a module that someone could replace with their own if they needed something more advanced?
I think that it should always be possible to disable this type of feature - I can see where it could be annoying. I would be fine with saving the tuning step in a favourite, it could probably be even better for the way I use the program.Max wrote: Sat Sep 19, 2020 6:51 pm No auto step for me thanks. If it was a feature it should be possible to switch it off.
Jim/Simon is there a way to close a tread for futher discussions when the problem has been solved? (tuning steps are added)
Yes there is, an Admin can lock the topic if they see fit.PD3LK wrote: Sun Sep 20, 2020 7:24 pm Jim/Simon is there a way to close a tread for futher discussions when the problem has been solved? (tuning steps are added)
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
IO92sc
G-QRP club 6129
Considered this, but decided to leave it open in case anything else came up on the subject.
Have never seen the value in "closing" relevant topics. The discussion usually expires naturally without any "state" intervention!
