I've taken a video which I've posted on youtube, however, the sound on the video is better (for some reason) than the sound heard from the SDR-Console
Any ideas anyone?
Hi Joanne,jdow wrote: Fri Nov 04, 2022 10:28 am The video captured within SDRC can have cleaner audio than you hear if your audio setup is off. Try running audio level down both in the sound control panel and SDRC itself. Then run it up slowly. That music is, to me, pure noise so finding additional noise on it is difficult.
I notice you are using an RTL dongle. Set the sample rate to 2.4 ksps. The screen suggests you have it set to 3 ksps. Don't Do That. I've never seen one happy at 3 Msps. They tend to top off at 2.4 Msps. I also always run with the dongle AGC off in case you went in and turned it on. I also run at a gain around "19 dB" give or take a dB or two. Too little gain can introduce noise. Too much gain can introduce cross modulation noise. If you are using the wee little antenna that often comes with the dongles - rig up something better. A 5 or 6 inch spike is puny. And get the antenna as far from the computer as possible.
{^_^} Joanne
Thanks Jim. Sound is sorted now!G0OFE wrote: Fri Nov 04, 2022 11:38 am Hard to say from that if there is any distortion due to the style of music, as Joanne points out.
Try and upload a recording with something less harsh, or some speech or something.
Hi Simon,Simon G4ELI wrote: Fri Nov 04, 2022 2:53 pm i would like to see just a screenshot so I can clearly see the settings, make sure the ribbon bar, Home panel is visible.
Please make sure you don't have any audio EQ enabled, but I don't see clipping so doubt this is the case.
I see the signal is not super strong, what's it like with a strong signal?
Hi Simon,Simon G4ELI wrote: Sat Nov 05, 2022 6:06 am Hi John,
Depending on the dongle 2.5 MHz is just too much. get a decent antenna and you'll see the RDS text. I also suggest zooming to the max to see more stations.
Looks better. Now switch on the RDS:AussieLand wrote: Sat Nov 05, 2022 11:22 amHi Simon,Simon G4ELI wrote: Sat Nov 05, 2022 6:06 am Hi John,
I tried a lower frequency, but I found that I couldn't get the span in the spectrum section, it was cut on the ends. It seems happy at 2.5 Mhz.
Anyways, I've been playing with itand this is the configuration I've come up with.'
