SDR Console and DAB+ ?
F6GLJ
Unread post by F6GLJ »
Hello, is it possible to receive DAB+ signal with SDR Console ?
Re: SDR Console and DAB+ ?
Probably not natively. An external decoder might do it.
Online
F6GLJ wrote: Fri Apr 14, 2023 3:21 pm Hello, is it possible to receive DAB+ signal with SDR Console ?
Sorry, no. I'll release a DAB+ decoder when the patents expire.
Simon G4ELI wrote: Sun Apr 16, 2023 6:55 am
Simon. Would it not be possible to integrate DAB and DAB+ like SDR Play do by needing a downloadable codec to enable (see attached), hence passing the responsibility for any potential royalty to the user/operator? Then it's for each user to make their own decision?
I actually think the DAB+ licensing is very poorly worded anyway. Talks about needing to pay a fee for "each product sold". No mention whatsoever of freeware. Pity these people don't think through the consequences of their sloppy wording.
Online
Max wrote: Mon Apr 17, 2023 8:46 am
No, this is not legal.
Simon G4ELI wrote: Mon Apr 17, 2023 9:43 am
Max wrote: Mon Apr 17, 2023 8:46 am Simon. Would it not be possible to integrate DAB and DAB+ like SDR Play do by needing a downloadable codec to enable (see attached), hence passing the responsibility for any potential royalty to the user/operator? Then it's for each user to make their own decision?
Perhaps someone should tell SDR Play!
F6GLJ
Ok Simon, thanks for your reply, I didn't know about patents ;-(
Online
F6GLJ wrote: Thu Apr 20, 2023 12:16 pm
It's the HE-AAC v2 audio codec. If / when I write a DAB/DAB+ program I would have to licence it, ~5 Euro / copy. Cost to me is ~1 Euro but there's a minimum amount to pay and then there's the admin.
sm7yes
Unread post by sm7yes »
Simon G4ELI wrote: Fri Apr 21, 2023 5:23 am
I'm sitting here with the ELAD S3 and can see a lot of DAB spectrum but can't listen. There is no solution from ELAD either...
I can pay for it no problem. Is there a possibility that you can put in a decoder but it won't work unless we buy an unlock key? Maybe there is a solution that we buy directly from the owner of the patents so that you don't have to be financially involved? Or maybe if you could consider doing a separate (profitable?) business on DAB for this obvious reason (which is highly motivated)?
Just some thoughts.
Sincerely,
Per
ELAD FDM-S3 with DCM and DL2EBV-6 bandpass
Elad FDM-S2
Winradio Excalibur G31DDC with Microtelecom FM+
Airspy HF+ dual port
Airspy HF+ Discovery
RSP1 clone, 5 ports
Apache Labs ANAN-100D
Sony XDR-F1HD Konrad mod
JRC NRD-535D
Kenwood TS-950SDX
