external radio issues with rtl-sdr and ic756p2
Alezis
Re: external radio issues with rtl-sdr and ic756p2
Unread post by Alezis »
iz1fks wrote: Sat May 14, 2022 9:45 am
I am having similar issues with a FT1000D on it's IF output.
Yours seems to scroll better than mine but I noticed in your video one of the issue I am also having, when you ZOOM the scope, there is a frequency shift happening and I saw it also on your video and I cannot figure out what cause this issue...
iz1fks
Unread post by iz1fks »
[/quote]
[/quote]
thanks for your reply, I think the issue is about software setting with CAT syncro as well as a software bug about zoom setting with CAT activated. I really don't understand why these bugs are not solved because the IF external radio option would be great with those problems fixed
Note that in SDRC zoom is ALWAYS around the center frequency of the display. Personally I consider that a bug. Simon does not. This is his toy. So I accept it.
iz1fks
jdow wrote: Mon Jul 25, 2022 1:59 pm Note that in SDRC zoom is ALWAYS around the center frequency of the display. Personally I consider that a bug. Simon does not. This is his toy. So I accept it.
the issue is not that is around center frequency, the problem is that the zoom level reset at each frequency change
CT2HUU
#15
Unread post by CT2HUU »
Hi
I have the same issue with the "auto zoom out"...
Did you find a solution?
iz1fks
#16
Hello, tried latest 3.2 version, no change on this issue. Radio->SDR setting doesn't work as it should and enabling sdr->Radio setting waterfall is okay moving in the right way while spectrum is freezed during vfo frequency changing. 73 and Merry Xmas to everybody
