TX led on Linear after HL2
Re: TX led on Linear after HL2
G8VLR wrote: Tue Aug 31, 2021 5:24 pm Okay Simon here are my settings:
Thanks. I'm sure it's not the software but internal switching, I've looked through the specs for the HL2 and the commands and it does look that way. Keeping in TX for longer seems to clear the problem.
What voltage are you using?
I'll keep thinking but am suspecting your unit.
G8VLR
Unread post by G8VLR »
Hi Simon, the HL2 and the linear are on 13.8v. I have noticed doing some tests this pm that if I tx with no audio the issue persists but if I talk into the mic when switching the issue does not reappear. Also I meant to thank you for fixing the meters problem, which no longer occurs.
Many thanks,
Roger.
