Here's a screenshot of the whole 6 MHz. Setting the S2's BW to 6 MHZ works, but everything is noisier than when it's set to 1.5 MHz.
@Paul: Yes, this also happens with FDM-SW2.
Bandwidth Issues on FDM-S2
Moderator: NN4F
Re: Bandwidth Issues on FDM-S2
I think your problem is the *very* strong MW signals. To receive properly above 2MHz you may need a HPF.W6UV wrote: Mon Oct 05, 2020 6:08 pm Here's a screenshot of the whole 6 MHz. Setting the S2's BW to 6 MHZ works, but everything is noisier than when it's set to 1.5 MHz.
Please adjust the display so the peaks of the strongest signals are visible, at present they are cut off.
Also,
A difference between the 6MHz and 1.5MHz bandwidths will be ~12dB less dynamic range with 6MHz compared with 1.5MHz. This may be the problem - those MW signals appear to cause you some serious problems.
So, I have a similar problem when increasing the bandwidth of the Elad S2 over 768 kHz. The problem manifested itself on the new ASUS ROG Strix G GL731GT-H7118T notebook (Windows 10 Home). In addition to the Console, the problem is also in the HDSDR programs and in the native program from Elad. It seems to me that this is not an overload of the ADC, since on my old Lenovo laptop a similar configuration of the receive path works correctly in all available bandwidths of this receiver.
Danila.
Danila.
Use a different USB port. Switch on the PSU.
Unfortunately, changing the USB ports, as well as supplying additional power through the USB hub did not solve the problem.
