Hey Everyone,
I am having a similar issue with Windows10. Launch the program, then 2 seconds later it dissapears. Here is my event viewer entry. Any thoughts?
Faulting application name: SimonsWorldMap.exe, version: 1.0.0.1, time stamp: 0x61e7121c
Faulting module name: d2d1.dll, version: 10.0.19041.546, time stamp: 0xdf04746a
Exception code: 0xc0000005
Fault offset: 0x000000000002d767
Faulting process id: 0xc78
Faulting application start time: 0x01d831730941b0e4
Faulting application path: C:\Program Files\Simon's World Map\SimonsWorldMap.exe
Faulting module path: C:\WINDOWS\SYSTEM32\d2d1.dll
Report Id: f78e0386-f5d9-46cf-9478-3523f8d70fa2
Faulting package full name:
Faulting package-relative application ID:
James
VA3JPX
Program will not run
Re: Program will not run
This kit https://www.dropbox.com/s/6dhaddktjqvae ... 6.exe?dl=0 has bugtrap so should create a crash dump when it has a problem. More testing tomorrow...
James_VA3JPX
Thanks Simon. Installed and it crashed. Here is the report for your review.
Cheers,
James
Cheers,
James
- SimonsWorldMap_error_report_220307-124403.zip
- (66.36 MiB) Downloaded 286 times
Please use this kit https://www.dropbox.com/s/3vjruh21w859o ... 7.exe?dl=0 I made an error and couldn't analyse the previous kit. With luck I'll be able to analyse this file.
James_VA3JPX
Hi Simon, thanks for the update. I installed this new version and here is the dump data.
Cheers,
James
Cheers,
James
- SimonsWorldMap_error_report_220308-170212.zip
- (66.05 MiB) Downloaded 318 times
James,
Many thanks. Here's another kit - I did fix a fatal bug but probably not your bug, so again please upload the crash dump.
Link to March 9th Kit
James_VA3JPX
Hello again Simon. Here is the dump data for March 9
James
James
- SimonsWorldMap_error_report_220309-104134.zip
- (66.25 MiB) Downloaded 320 times
Thanks, now let's see if I can analyse it properly.
OK,
I see where it crashed but don't understand why the program failed to initialise properly. You have W10, I assume more than enough resources but for some reason this program was not happy.
Below is another kit - this will probably crash, if not then I doubt you'll see a map.
Here's a new kit
Here's a new kit
James_VA3JPX
It works!! But yes, there is no map.
James
James
