IF gain setting while recording I/Q ?
F1GOC
Unread post by F1GOC »
What is in your opinion the best setting for IF gain when recording I/Q over a 2Mhz frequency range? Auto or manual ?
Regards
Michel (F1GOC)
Re: IF gain setting while recording I/Q ?
Which SDR are you using?
If it's the SDRPlay, then I always use manual in order to keep the gain constant in the event of strong signals coming and going.
F1GOC
Thanks Jim
I'm using a RSP-2 from SDRPlay. I will try to record with fixed IF gain.
BTW, what is the bandwith which gives the best RX performance, if any ?
Michel (F1GOC)
