RX-888 Info
RX-888 Info
From Justin Peng
RX888
Based on FFB103:
  • improved HF filter design
  • added VCXO clock and shield
  • added LT6401-20 LNA for ADC pre-amplification
In addition, the LPF bandwidth is designed according to 65M, and subsequent extio and firmware have the opportunity to increase the bandwidth to 64M.
sm6fhz
Re: RX-888 Info
Unread post by sm6fhz »
Thanks for info Simon.
Does / will SDRC support the RX-888 as well as the RX-666?
Are there many changes that need to be done to the interface in order to support the RX-888?
73 / Ingolf, SM6FHZ
sm6fhz
Re: RX-888 Info
The LT-6401-20 looks like a good choice to me for a pre ADC amp here. It is specifically designed for this purpose and is capable of a 6.2 dB NF up to 100 MHz and a +55 dBm OIP3 at 30 MHz.
I am looking forward to receiving the RX-888 and try it out with SDRC :-)
Does the RX-888 need any different drivers than the RX-666 in order to work with SDRC?
73 / Ingolf, SM6FHZ
on2ron
Re: RX-888 Info
Unread post by on2ron »
Can't find nothing about the filters of the RX-888. All I can see is a LPF in the VHF/UHF stage. Is there bandpass filtering on HF?
73' Ron
ON2RON
