Help with Auto Mute if used as Panadapter needet...
DO1ATM
Unread post by DO1ATM »
Dear Sirs,
Im using a RTL Stick and Omnirig as Panadapter on my FT-950 an it works very well.
Usulay the computer audio is turend off and I'm working only with the Waterfall BUT sometimes I like to use the Computer Audio special for weaker Signals.
But when im sending I hear myselve over SDRConsole and this is annoing.
I tryed to configure Auto-Mute over the Tool Tab but had no luck with this.
Can anyone help me out ??
thank you
tom[/font]
Re: Help with Auto Mute if used as Panadapter needet...
Hi, did you tried to disable TX monitor? (see red circle)
73, Leon
DO1ATM
Thank you for answering. Unfortunately the whole Transmit section is grey and not accessible.
I thoght this is for sending with eg. HACKRF or so ?!
How can I get this accessible ?
73 tom
Sorry Tom, TX cannot be enabled with a RTL stick ofcource. Should have read better, my bad.
I think there's no way to tell SDRC it has to mute when you are transmitting with an external TX but there are hardware solutions like this one:
https://nl.aliexpress.com/item/1005001392348124.html
m3ghe
Unread post by m3ghe »
PD3LK wrote: Wed May 19, 2021 6:18 pm Sorry Tom, TX cannot be enabled with a RTL stick ofcource. Should have read better, my bad.
No Tom that isn't what he needs. That item is to allow you to share the antenna between your transceiver on TX and your SDR on RX.
All he needs is a method to mute the PC loudspeaker when transmitting and there is various simple ways of doing this.
A relay controlled by the PTT line of the TXCVR disconnecting the PC speaker/headphones is the easiest to construct. A little more complex is a RF switch to do the same thing.
I'll see if I can find a production solution.
Martin
m3ghe
IO92sc
G-QRP club 6129
m3ghe
One question are you using the RTL SDR connected to the IF output or to the antenna?
Martin
m3ghe
IO92sc
G-QRP club 6129
DO1ATM
@Leon: Thank you, but I think Martin got it.
@Martin: I think you got it *g*. Yes, I'm using the internal IF for the RTL Stick. I hoped there was a way in the Software to Mute the Audio while sending. So, as you describe, I think I have to grad the RS242 signal with an Arduino and cut the IF input for the Stick While sending. Seems to be not too difficult to do..
I wonder if he has tried "home->options->AutoMute. Check the checkbox and set the muting levels. This only works if the signal when TXing is maybe 10 dB larger than incoming signals as a minimum.
DO1ATM
jdow wrote: Thu May 20, 2021 10:42 am I wonder if he has tried "home->options->AutoMute. Check the checkbox and set the muting levels. This only works if the signal when TXing is maybe 10 dB larger than incoming signals as a minimum.
Thank you,
but as you can see in the initial post ... Yes. But it did'nt work as in the Screenshot (wrong Parameters maybe ?).
DO1ATM
m3ghe wrote: Wed May 19, 2021 9:15 pm One question are you using the RTL SDR connected to the IF output or to the antenna?
The Stick is connected via IF output.
I think I can take the RS232 Signal, read it with a Arduino an switch a Realis if there is no posibillity in the Software ..
