3.0.28, Release Notes
Links to kits, all release notes 💾
Kits
The kits are on the download page.
3D Waterfall
This is the main new feature. For more information and a couple of videos just click here.
  • Ribbon bar, View, Waterfall, 3D.
  • Requires Windows 10, DirectX 12.
Here's a screenshot
Here's a screenshot
Datafile Editor
Added a page on the website.
Broadcast FM MPX
The Broadcast FM MPX option is now saved between sessions.
Serial Port
Serial port command SM reply was incorrect, only returning 4 digits instead of 5.
Audio Recording
Fixed recording SAM with binaural (stereo) enabled.
Audio Playback
Reduced clicks in the output.
ELAD S3
Fixed bugs in data flow control.
Performance
Added more program optimisations.
Receivers
When clicking on 'Select' in the Receive pane to change the active receiver a small safeguard has been added to catch unintentional double-clicks which resulted in a frequency change.
Satellites
Automatic IQ recording of satellite passes should now honour the Automatic Schedule.
KA6MOK
Re: 3.0.28, Release Notes
Unread post by KA6MOK »
Hi Simon...
Wanted to let you know, that I downloaded from the Microsoft (and I think Google?) "boxes" got a file labeled 3.0.28, that ended up loading 3.0.24??
The Dropbox one contained an actual 3.0.28.
The 3d display is pretty cool... now that I actually have the update! Will run around and check everything else out...
feathers632
Unread post by feathers632 »
Have been trying to download 3d waterfall for the past 20 minutes. All I see is fake download links from Ads.
Adblocker works wonders.
Anyway, scroll down about 2/3 the way down on the 'Downloads' page (slider on right) until you see the image of the World Map (another awsome piece of software BTW). Then click on the appropriate 32/64 bit version and download from one of the many locations where it's stored.
V3.3 from Feb 5th, 2024 is the latest public version.
Be sure your computer meets the minimum requirements:
https://www.sdr-radio.com/3d-waterfall
See attachment!
