strange behaviour using multible receivers
VK5HW
Unread post by VK5HW »
G'Day,
I've just noted that there seems to be an issue when running multible receivers.
Say I have three RX's, 10/15/17, and audio going to three different cables (virtual). I can get only two outputs to work. Strange think is if I make the last RX (17) the active one, it produces audio but RX one (10) deactivates.
Just noted that if I add another RX (20), 20 has audio output but 17 doesn't however, selecting 20; 10 stops and 15/17/20 work.
I can't be 100% sure, but from memory (its like Swiss cheese) I've had this working with at least six receivers with an earlier version.
I hope the attached screen record shows what I'm trying to convey.
73 Hauke VK5HW
SDR-C
Ver: 3.1 build 2320
2021-11-22_10-18-59.mp4
(8.72 MiB) Downloaded 215 times
VK5HW
Re: strange behaviour using multible receivers
I must clarify. The RX is not deactivated nor is it muted. It does'nt produce any audio is what I tried to convey (not very succesful I think).
Hope that clears the muddy waters a bit.
pls tell us what VAC software you are using? Is it maybe a restricted free version?
grtz, Leon
