Radioberry black board (Hermes Lite) no TX
PeterW
Unread post by PeterW »
Hi guys
I have a Black Radioberry board that comes from Aliexpress witch I testing out.
First with SDR-Console V3.1 2320 and it is same hardware as Hermes Lite RX works fine but when I hit TX nothing is transmitted, the PTT out on Radioberry works it activates on TX
but no RF at all.
I thought it could be some faulty board but when I tested the board in SparSDR software TX worked OK
I have seen in (Hermes Lite- radioberry google forum) that there has been problem with some Radioberry boards in SDR-Console
So is there any new news about this for SDR-Console ? can I se some logging other than the logg file what is happening when i press TX, as i mention the PTT out
on Radioberry is activated on TX so the board receives TX but can not modulate ?
The meter does not show anything either.
73's SM6NTR
Re: Radioberry black board (Hermes Lite) no TX
I didn't even know that this board exists! You can attach the logfile and screenshots to a reply, maybe there's some information there, but again this is the first I've heard about this SDR, maybe you can send me a link?
PeterW
Simon G4ELI wrote: Wed Jan 19, 2022 2:08 pm Hi,
Ok here are some pictures and loggfile from SDR-Console
Radiberry_black is my board with custom test cooling mounted.
The other pictures are from Aliexpress site and SDR-Console in Receive and Transmit also the loggfile from first connect
SDR Console tmp.txt
(14.93 KiB) Downloaded 363 times
Scrroll down in the TX options, please show me the Spectrum window, I want to be sure you are generating audio.
Use the Tone option as well (Drive set to 100) - we should see some ALC action, your screenshot with TX on shows no ALC so either the input device is not working / connected or there's another problem.
PeterW
Simon G4ELI wrote: Wed Jan 19, 2022 3:00 pm Thanks,
Ok but i havent tested audio yet only AM and FM to get out carrier but no RF outputted, also I tested 2 tone but no RF
But I can connect MIC to and se if it that works.
I get back here little later this evening.
BR
You must have a Microphone connected!
PeterW
Re: Radioberry black board (Hermes Lite) no TX Solved !!!
Simon G4ELI wrote: Wed Jan 19, 2022 5:18 pm Hi,
Hello again Simon , yep I have found the problem , microphone was disconnected in windows even if it was connected it was not allowed to use, i have a external mixer for all sound in/out normally so
for some reason it was not allowed directly to windows.
So now it works Ok with SDR-Console also.
I was a bit confused when i could TX with FM and AM Carrier only in the other SparkSDR but not in SDR-Console
Think's for support Simon and your great software
I have added to the subject with solved .. could not change the original top subject :-(
best 73
SM6NTR / Peter
PeterW wrote: Wed Jan 19, 2022 6:43 pm
best 73
SM6NTR / Peter
Just FWIW and I MUST document this - a working microphone is needed as the samples from the microphone are used to pump the whole transmit chain. Anyway, glad it's working.
And tell your friends - I want to make the TX side user-friendly this year.
PeterW
Hello Simon
I have another question about CW, I saw in the settings that i could use a Serial comport CTS signal to activate PTT but TX (Ptt) button does not give any RF out
is there a setting for this in SDR-Console or is it depend on RadiooBerry Firmware ? (Hermes Lite)
Peter
