My first setup of SDR-Radio with FDM DUO. Most likely I am overlooking something in my configuration.
TX works, but RX not (no audio signal nos waterfall).
FDM-DUO works fine in RX and TX with FDM-SW2 on the same PC.
SDR-Radio 3.1 works fine with RTL, Airspy and Hermes (RX and TX) on the same PC.
73 de Fredi, HB9BHU
Elad FDM DUO - no RX / input stream
Moderator: NN4F
- SDR Console tmp.txt
- (19.21 KiB) Downloaded 350 times
Re: Elad FDM DUO - no RX / input stream
WoW!
- Check you have the latest firmware, let me know which version you have. Click Options in the Radio panel (left-hand side), there's a page with this info.
- Try disabling the preselector.
