SDR Console 3.1 recording bug (maybe?)
tony1tf
Unread post by tony1tf »
Hi Simon et al
I have got back to SDR Console after a long break, and I am trying to use it on a small mini-PC running W10. It uses a T2250 1.73GHz CPU with 2GB of RAM.
SDR Console 3.1 build 2320. AirSpy or FunCube Dongle, both receive OK, but if I try to record audio or data, the program locks up and the only way out is with CTRL ALT DEL. I have attached a screendump, and the log file before it locked up.
Tony
SDR Console tmp.txt
(26.78 KiB) Downloaded 281 times
Re: SDR Console 3.1 recording bug (maybe?)
Please take note of the computer requirements here...
https://www.sdr-radio.com/computer
73, Leon
tony1tf wrote: Mon Feb 07, 2022 6:54 pm I have got back to SDR Console after a long break, and I am trying to use it on a small mini-PC running W10. It uses a T2250 1.73GHz CPU with 2GB of RAM....... If I try to record audio or data, the program locks up and the only way out is with CTRL ALT DEL.
Tony, that PC is working very hard in the screengrab:
To give you an idea here's my 10 year old i7 PC running RSP2Pro:
Think your PC must be underspecified sadly as Leon says.
tony1tf
Thanks for the suggestions. I have run SDR Console on all sorts of old PCs in the past. Do you think that going back to a older version in Simon's now unsupported versions would require less resources. I only wanted to record some data from an Airspy in the SDR Console format for someone else to review. The Airspy works perfectly well on the same PC with HDSDR.
Tony
