Command line parameters
The ability to read at least a couple command line parameters might be nice.
The first is "/i" (or -i or --identity). It's parameter would be the identity name.
for example: /i "HF SWL RX888 MKII"
The second is "/a", -a, or --autorun. A parameter could permit a delay before fully initializing the program and starting to run.
And if something like this is already implemented, perhaps the sdr-radio.com documentation could reflect this.
(I can sketch out how to do this if you've never done it. Microsoft documentation is Microsoft clear in this regard, as usual. As it turns out it is quite easy.)
